When I started reading this thread i was thinking alternator too.
Had a similar problem about a year ago.
One of the three wires into the alternator is a feed from the ignition live.
In effect it's a signal wire to tell the alternator to output the current its producing.
This wire was cracked in my case and would result in a very similar intermitent problem.
When the battery eventually died, i would get very similar results.
(incedentaly because the alternator is not
"switched on" you dont get the dash lit up like a christmas tree warning)
What moves me away from the alternator are a couple of things.
Firstly the car runs fine on just the battery until it is drained.
When it's drained the first thing that went for me was the power steering.
I would typically have about a quarter of a mile before the engine died.
Secondly i would be very suprised if the car would start again if the battery was discharged to the extent that the speedo/ignition stops.
I left a multimeter wired across ignition live and ground to show the voltage as i was driving
- could tell when the alternator was switching off.
This would at least tell you what the alternator is putting out.
If this still reads
~14v when your speedo goes, i would rule out the alternator
(subject to more knowledgable member happening by
edit to add: voltage would be
~11v if alternator is not working
