I've got pretty much a standard setup on my Rev3 Tubby.
New turbo about 3 years ago and HKS induction kit.
When the OEM BOV operates occasionally
Hard to describe but needless to say it's annoying.
Steve
Tom Solan wrote:Hi guys,
It's nothing to do with BOVs'.It's the air induction kits that do it.
I get it on virtually every car with an a/am air kit and even those with no a/m BOV
Tom
NVI
Tom
NVI
sconisbee wrote:I suspected it was going to be something to do with the Induction Kit as it does make all turbo noises much louder.Not really sure what to do now as the noise is horrible.
It goes away if I stick an aftermarket VTA valve on, but then the car doesn't go properly.
Mind you, thats sticking a valve in the front most intercooler pipe.
Is it worth trying on the cold side? Or maybe even saucing an aftermarket recirc valve?
Can you get a bolt on replacement for the MR2 to avoid cutting pipes?
