imoc does not work on my pc
Re: imoc does not work on my pc
Alex_Dunn wrote:whats firefox???
its a new browser for the internet that is
I had some issues with this site with Internet Explorer but its ok now
How abot tools/internet options/security and check the list of restricted sites,
& set all the zones back to defaults.
Guarenteed to work
If your getting a 404 error it means that the browser is most likely pointing at the wrong webserver.
Which wither points to DNS or an iffy local hosts file.
Do ping
"www.imoc.co.uk" and post back the ip address.
Do ping
Forever Feels Like Home, Sitting All Alone Inside Your Head.
i just installed firefox and put in imoc and it came up with
bad request invaled hostname
ping www.imoc.co.uk and tell me what it says
ok,
Open a command shell,
(Start
-> Run
-> Type CMD then press enter)
When the black box appears type
"ping www.imoc.co.uk" and tell me what the number says.
I have highlighted it in red here.
it came up with
[213.171.193.29]
with 32 mb of data, does this mean
ne thing??
Alex_Dunn wrote:it came up with[213.171.193.29]
ne thing??
Aaah, now we're getting somewhere.
Code: Select all
Non-authoritative answer:
Address: 213.171.219.195
Did you do Neil Johnson's hack to add www.imoc.co.uk to your local
ne thing??
OK, at least that shows
For the next test, open a cmd shell again
I really only need the bits i have highlighted in red.
While we are tracing this fault, it would be handy to get the ouput of your
"ipconfig
/all" screen.
From a cmd shell, just type the following.
ipconfig
/all
>c:\ipconfig.txt
then email me the c:\ipconfig.txt file so I can have a look.
Neil.
ipconfig
Neil.
BenF wrote:Alex_Dunn wrote:it came up with[213.171.193.29]
ne thing??
Aaah, now we're getting somewhere.That address is wrong, the IP address should be
Code: Select all
Non-authoritative answer: Name: www.imoc.co.uk Address: 213.171.219.195
Did you do Neil Johnson's hack to add www.imoc.co.uk to your local'hosts' file? If so, remove that entry as it points to the old NT server we were hosted from.
lol i think your going to have to dumb it down to how he actually does that ben as that means nothing to most but me here i think
ok latest results
server: jd.mshome.net
and you have mail of the ipconfig
And thats what makes IMOC so special
& the best forum on the net
!! well done Jonno, top advice
, Jinxy
OK, the fact that nslookup is correct means that your DNS settings are correct.
The fact that your ping setting is wrong means that your local hosts file is probably wrong.
Open the your c:\windows\system32\drivers\etc\hosts file
(Start
-> Run
"notepad c:\windows\system32\drivers\etc\hosts")
and look for a line like this.
213.171.219.195 www.imoc.co.uk
If you find one comment it out completely by putting a
"#" at the font.
#213.171.219.195 www.imoc.co.uk
Then save the file and try accessing the website again.
Neil.
Neil.
jonno wrote:Open the your c:\windows\system32\drivers\etc\hosts file(Start
-> Run
Was hoping this would solve my longstanding problem of accessing
The Windows file in question though is pretty much empty so it didn't help.
Also, when if I connect via dial-up
