black
74,000 miles
full service aboout 500 miles ago with trd oil filter, oil/gearbox oil, new colder grade plugs etc
new track rods ends
new steering rack gaiters
rear inner and outer cv joints
2x inner driveshaft boots
brand new battery
ebc drilled and grooved brake discs
new brake pads
new kyb shock absorbers
tein s tech springs
full high and tight motorsport bush kit
22mm trd front anti roll bars
25mm trd rear anti roll bars
hks hyper exhaust with centre box removed
xxxx fuel cut defencer
sbitsl boost controller
hks superpower induction kit
magentic sump plug
ngk colder grade plugs
rps
fidanza flywheel with arp bolts
autometer
60mm boost guage
52mm oil pressure, oil temperature, water temperature(not wired in)
dials converted to mph
dash converted to whits leds to match guages
omp 300m race steering wheel with omp hub
new gearshift gaiter with 8 ball knob
rev 3 rear light conversion
rev 2 front lip
bomex drift wing
17'' hi-join rims in black good condition tyres
the bad bits
unfortunately some of the bodywork has been vandalised by a jealous ex girlfriend of the previous owner so some of the panels have key marks
the centre console is broken at the bottom around the ash tray but this is a fairly cheap fix bout
the drivers seat has a rip on the side bolster
she runs and rides brilliantly just needs some tlc cosmetically, ill be sad to see her go considering how much the car has cost me too build, all the mods are under 3000 miles old so basically brand new
and some pics of the damage
