Does a rev 3 have a lsd
BARON
Post by BARON »
hello people, ive eventually got round to getting a tubby, im going on saturday to pick up a 94 rev 3 turbo, do they have lsds,, do they have any perks
BLOODUK
Re: Does a rev 3 have a lsd
Post by BLOODUK »
http://www.btinternet.com/~netsurf/mr2t ... _Slip_diff
To verify if your car has a LSD, check the vehicle identification plate on the inside of front bonnet. There are a number of codes given there, including the transmission type, whose code starts with the sequence "A/TM"
For example, A/TM:- 735/E153
If the last digit before the /E153 is a '3' or a '5' then the car has a LSD - therefore in the example above it does.
Found out mine has lsd , Rev 2 ;)
TheRed2
Post by TheRed2 »
Mine is 3E5F E23 472S54
So do I have LSD? :-k
Mine is a 95 UK NA.
senie
Post by senie »
i was under the impression all rev 3 or later tubbies had LSD.
Boffins. can we confirm? Just ensure the tubby is manufactured after 94 and not just sold after 94. could be a big difference. check the bottom of seatbelt for this.
raptor95GTS
Post by raptor95GTS »
my 95 turbo has the LSD
Patrick Gray
Post by Patrick Gray »
think a lsd was standard equipment on all rev 3 turbo's
KiwiMR2
Post by KiwiMR2 »
senie wrote:i was under the impression all rev 3 or later tubbies had LSD.
AFAIA it was an OPTION through out the series, however I think something like 80% of them have it.
KIwiMR2
Patrick Gray
pretty sure it was a factory option on the rev 2 mate and standard fit on the rev 3
Joey
Post by Joey »
Standard from Rev 3 on
BARON
Post by BARON »
lol ive stirred some confusion now, il check it when i get it, or use the good old method of, fryin the wheels of the mark, two even trails of smoke and thats sort of a tell tale
Mikejc
Post by Mikejc »
Rev 3+ cars regardless of spec should have an LSD fitted as standed :D
Mikejc
KiwiMR2
Post by KiwiMR2 »
Well looking at the Toyota EPC for j-spec cars it says from 12/91 it is STANDARD.
KiwiMR2
BARON
Post by BARON »
cheers lads, some good info there on the link BLOODUK
Vindezal
Post by Vindezal »
BARON wrote:hello people, ive eventually got round to getting a tubby, im going on saturday to pick up a 94 rev 3 turbo, do they have lsds,, do they have any perks
Yes
BLOODUK
Post by BLOODUK »
BARON wrote:cheers lads, some good info there on the link BLOODUK
BARON
Post by BARON »
lol i get the hint vindezal, theres a lsd in it
Bobby (aka Shaggar)
Post by Bobby (aka Shaggar) »
rev2 onwards
