See before you buy wheel simulator
stevenb
Post by stevenb »
Found this link from NPOC.
I changed the settings to get a mk1 MR2.
If you have a different MR2 then go to 'My Vehicles'
Then you choose from the 'select a vehicle below'
Manufacturer and year click on 'Go'.
Then in the top drop down menu select your car model ie MR2
click on 'continue without saving vehicle'
Then choose the 'wheels' icon. and sure enough a piccy should show of your car.
Although these are american wheels some are available over here and some just have a different name. but it gives you an quick visual aspect of how say....a five spoker wheel to a split rim multispoke would look...
http://www.tirerack.com/upgrade_garage/ ... toModClar=
The link above is for a mk1 but you can change it as described above.
sorry if this has been posted before. :oops:
i thinks its really cool. :D
Rich
Re: See before you buy wheel simulator
Post by Rich »
I just use GT4 :P
WinFreak
Post by WinFreak »
Link dont work overhere... :o
<center>Image
stevenb
Post by stevenb »
WinFreak wrote:Link dont work overhere... :o
Just go to www.tirerack.com and then you should be ok..... :wink:
WinFreak
Post by WinFreak »
Ah thanx, i allready new that one...
Best way is still photoshop i think
<center>Image
