ryan_s3 wrote:so bigger injectors needed at 320bhp..
.what about the fuel pump does that need upgrading?
ryan_s3 wrote:thanks dino,
think i'm coming back to the two again.Is it easier to run a in-line pump rather than dropping the tank which i did last time as it was a pain in the ass
ryan_s3 wrote:.How much are the m4 install going for now?
ryan_s3 wrote:So what do you suggest i do,there's not many"built" two running around and how new does the block have to be in order to avoid the thin walls?
Mikejc wrote:I dissagree regarding the fuel pump.On the bases that if it were not up to the job then it would not allow enough fuel for the injectors to hit 100% injector duty!?
ryan_s3 wrote:However, I did infact replace the standed fuel pump for an uprated Walbro item as a matter of course.Given that most of our cars are approching 10 years old, it makes good sense to replace just in case the old unit should fail due to age
ryan_s3 wrote:As for the early rev3 blocks being weaker, this is very true.But according to the research of JJ, they are only a fraction thinner and not the problem some make out.
Specially if you have chosen your supporting mods well
MR2Mania wrote:
IMHO, if you want a reliable 300+bhp stock motor, then you sure as hell would want to know that you haven't got a thin walled block.Sure, it's not worth rebuilding
"just in case", but it's worth noting in the back of your mind that, someday, the block might crack, and then you'll need to consider some
(costly) options.
ryan_s3 wrote:The prices of post 98 tubbys are massive,it's probably cheaper to have to have a full rebuild in a early rev 3(or does this not solve the thin wall problem??).
I had the walbro pump on my last tubby,but it really whined,got on my nerves!!
