I kneeeeeew this would get posted, Ive just searched for
EK9 on every MR2 owners forum I could find.
It was me mate, it is indeed an EK9, a 2000
(W plate) Civic Type-Rx.
I have to say that youve got me wrong about going past you and thinking it was all too easy.
I knew youd either fluffed a gear change or you just werent biting.
Im well aware of what an MR2 Turbo is capable of, which you demonstrated to me on the next stretch.
You slowed right down, let me go by and then must have come on boost and went for it? You were flying
Much to my annoyance I actually dropped out of VTEC when going from 2nd to 3rd, which as you may be aware will punish you, they arent quite as easy to
drive fast as the newer Civic Type Rs with the fancy gearbox and more torque, if you drop out of VTEC in an EK9 you wont get anywhere, as kmb says you have to rev the boobs off them.
They arent the fastest cars on the road but Christ; theyre so much fun to drive and more importantly, unique.
AFAIK there are less than 50 in the UK, which may explain you not ever seeing one before.
It obviously made you take notice though to do a little research afterwards?
