Theres alot more to making power than the amount of boost you run.
Sometimes running more boost can result in less power.
Its about how much air the turbo can shift at a given pressure.
Its CFM that matters when tuning an engine.
I ran 16-17psi on a gen 2 totally stock engine, and for about 3 months I pulled off the wastegate pipe and just let it spike to 20-22psi and it would drop down higher up in the revs and it didnt perform an better than running the 16-17psi.
As you increase the pressure, you increase the heat, therefore you need better methods of cooling the intake charge.
Bigger intercooler, or move to a larger turbo with less boost.
You need to determine the power level your going for and choose a turbo for that application, alot of people just whack on a big turbo and usually spend more money than they need to and actually sacrifice some low end power too.
I run 22psi at the moment and will be running 26psi when I get round to doing a few more alterations to my setup.
But that is where my turbos efficiency is at its maximum, running higher boost would be a wste of time, then it would be time to change to a different turbo.
The engine should be designed and balanced in harmony, or you end up with bits too big and bits too small, and a real mess.
Renault 5 GT turbo are not a bad engine really, I wouldnt have one myself, but people expect too much of them for too little.
Graeme
