Righto, time for an update.
I didn't manage to do anything with my caliper until today due to a huge short-term uni project.
I ordered the pistons from Brakes International and opened them up this afternoon, noticed they're not correct!!!
The internals of the pistons were different to the actual ones off the brakes off the car.
So they wouldn't screw onto the caliper.
Now I realise that I may have been missing something with the pistons, but basically they had not thread in them and it looked as though they were designed such that you remove the internals from the old pistons and put into the new ones.
But I couldn't figure out how you get the internals out the old ones.
Well, my MOT is booked for Tuesday and frankly I don't think I can hold off much longer if I still want to make the MR2 World Record attempt at the end of the month
- it's either this week or I don't go.
So I cleaned up the old piston from one of the other calipers I had
- polished it with wet and dry 1200 I think.
Not much at all, just enough to get the crud on the surface off.
Cleaned off the caliper and put everything back together.
I think.
Right, here's the question.
When I started off, I had the following items in the recon kit:
Then when I finished, I was left over with the following
(i.e.
unused):
Is that correct? I assumed that these kits could apply to a different car as well it could have other parts.
Last time I did this job on these calipers I also didn't use these parts; but that wasn't a full
"take off car and refurb" job.
Plus, I had another caliper next to me with all the seals still on and couldn't see where these were on that one.
soooo.
Basically, before I put the car through MOT, have I forgotten anything?
Cheers!
-Max
Edit: Before someone says that I'm not supposed to do that to the old piston and it's not a good idea, etc, I'm on the phone to Brakes Int on Monday to find out what's going on.
I'll either get a new piston and swap over, or I'm thinking I may even just give in and go get fully reconned calipers direct off them.
Expensive, but given how this caliper still looks dirty and mucky, in spite of hours of cleaning and wire brush applications.
I'm beginning to think the extra money may be worth it.
