Booked a couple of days off work to get all the bodywork sorted on my car.
Paint
The main part of the spraying will be the bottom lip of my front bumper.
Thanks in advance for any help!
bowmont wrote:if your spraying over alloy you will need eching primer it wont stick if you just rough it up and spray over it plastic primer for plastic one coat should do then normal primer couple of coats of that i have got two air extractors in my workshop it will help to keep an constent air flow to help to stop over spray top coat celly paint easiest but srinks over time and tats if you get it as now they have band it or a base coat and celly laquer thats if you ar going to use an air compresor depends how much spraying your going to do i recomend get it in to a spray shop i been doing my xr3i for 10 months now on and off and its been a pain due to it being a met mercury grey and cant get hold of celly this colour any more so am using base coat a celly laquer its been a right pain still not happy with it![]()
