[Mk2] [Turbo] how much mpg/milage off £15
skyline
Post by skyline »
me and my friend got same cars(mr2 turbo) with roughly same mods.we both put £15 in each from empty.we didnt use motorways so only from 1st to 4rth gear back and 4 to work etc.we didnt boot it and i got 92 to his 59.
just out of interest how much mpg or milage u get out of ur turbo cars off £10-£15
jont
Re: [Mk2] [Turbo] how much mpg/milage off £15
Post by jont »
I usually get high 20s to the gallon (averaged over several thousand miles of running). Current fuel prices that works out at about 15-16p/mile. So I'd expect about 100 miles from £15. 92 miles doesn't seem too bad.
ducatichick
Post by ducatichick »
anything over 85 is normal.
imo :wink:
Ian Geary
Post by Ian Geary »
tyre pressures
junk in the boot
short trips with the car not warming up
excess braking / accelerating
All of these things can affect mpg, as advertised by our Government here:
http://www.dft.gov.uk/ActOnCO2/index.ph ... and_advice
Personally, I'd ignore the one about changing up at 2,500 revs though...
Ian
luthor1
Post by luthor1 »
I get between 180 and 220 miles from between £35 and £40
(if that helps??)
I think it's around 21-25mpg. Rev2 though, so crappy AFM.
jimGTS
Post by jimGTS »
how empty is empty?
you phyically drained all of it out and measured how much you put in?
the fuel light can go on for a good 20-30miles, so i wouldnt base it on this fact alone....
only true way of measuring is to have half a tank, fill it up, note the ltrs and ££, drive to roughly half a tank again, fill it up to the brim again, this way you can work out exactly how much your putting back in and the ££ again to work out mpg....
dan9
Post by dan9 »
It's worth searching for threads on MPG and fuel economy - there are loads!
If your fuel economy is consistently low, no matter how carefully you drive, then consider checking the lambda sensor (again, loads of threads on this if you search).
Mine was busted but didn't report any error codes. Only evidence was high emissions and running (even more) rich.
Since I replaced the sensor I get about 33mpg (compared with about 25mpg before).
mr2neil
Post by mr2neil »
omg, is there sumthin wrong with my car?!?
i always fill it up and get exactly 200 miles out of the tank, thats showin on the E line but without the fuel light on, its always done that in 5 years of ownership, an mainly around town driving!
dan9
Post by dan9 »
mr2neil wrote:omg, is there sumthin wrong with my car?!?
Sounds like it!
If it's an NA then 30mpg (260ish miles) should be fairly easy to get, if a turbo it shouldn't be loads less...
skyline
Post by skyline »
could it be that if the water temp isnt workin,wud that effect the fuel?
EarL
Post by EarL »
The MoTeC makes the fueling off boost so much better than the stock ECU. On a full tank, I've seen 376 miles and still going. :wink:
When it's hitting 1.5 bar though, I'm hard pressed to get more than 8 mpg from it. :lol:
EarL.
alan mc
Post by alan mc »
I get well over 270miles to a tank full of petrol on a mainly motorway journey, around town I would imagine it to be somewhat less 8)
alan mc
Post by alan mc »
EarL wrote:The MoTeC makes the fueling off boost so much better than the stock ECU. On a full tank, I've seen 376 miles and still going. :wink:
EarL.
I could do with a Motec :D :mrgreen:
whitworthmike
Post by whitworthmike »
That's exactly what I get from my N/A. If you've got a problem......MINE MUST BE COMPLETELY SCREWED!
Spittinflames
Post by Spittinflames »
Around town i'll get around 50-60 miles on a tenner, I do alot of short, stop start journeys though.
It all depends on how yo drive etc....
