Later on it started doing it again with the end result i ended up driving the whole way home in 4th gear
BenF wrote:You contacted Spec or the place you bought the clutch from about this at all?
luthor1 wrote:Slam them as hard as you can on all the forums, showing your pictures and carefully destroying their reputation.
Meanwhile, go to xxxx and buy an RPS clutch off him relative to your BHP and TORQUE, then enjoy perfect clutch action for ever more- well 10's of thousands of miles!
Spacey wrote:I must be the only person happy with my Spec clutch, although mine is stage 3 and rattles/chatters a lot.
That does sound bad though mate.
