[Mk2] [NA] Warning light
jon_84
Post by jon_84 »
Hello again. I hope some body can help. When driving along the Engine Compartment Cooling Fan Warning Light comes on. We have checked the engine bay teperature sensor but that seems absolutely fine, has anybody ever had the same problem or a similar experience???
any help would be great!
Andy Champ
Re: [Mk2] [NA] Warning light
Post by Andy Champ »
jon_84 wrote:Hello again. I hope some body can help. When driving along the Engine Compartment Cooling Fan Warning Light comes on. We have checked the engine bay teperature sensor but that seems absolutely fine, has anybody ever had the same problem or a similar experience???
Does the fan ever start? Does it start if you unplug the sensor? Does it start if you sit in traffic for a while?
Andy
jon_84
Post by jon_84 »
No it doesnt start at all. We tested the continuity of the relays and they are all fine. The fan worked when we attached it to a power supply. Im at a loose end as everything else seems to be okay.
Jon
revturbo
Post by revturbo »
unplug the sensor and put the ignition on....the fan should come on constantly, if it does then you need a new sensor and if it doesn't you need a fan!
jon_84
Post by jon_84 »
I have done that but the fan still doesnt seem to want to kick in. Like i said the fan worked fine when it was hooked up to a power supply but other than that there isnt any life.
Jon
star_gazer
Post by star_gazer »
jon_84 wrote:No it doesnt start at all. We tested the continuity of the relays and they are all fine. The fan worked when we attached it to a power supply. Im at a loose end as everything else seems to be okay.
Jon
Is the relay actually working? Even a burnt out relay can pass the continuity test :|
As mentioned earlier follow the logical step, if fan works on separate power eg battery, Fan is OK, if sensor is removed and working fan does not work trace the wirings/relays for faults
good luck :thumleft:
Slarty
Post by Slarty »
Jon
Exactly what that man said :)
If the coil of the relay is ok, it doesn't mean that the contacts are ok!! The relay could be switching on, but current won't be passing through the possibly burnt out contacts.
jon_84
Post by jon_84 »
okay then thanks i will try that then,
