ok lower.
.internally on all mr2 rear calipers there is a small mechanism that doesnt come into contact with the piston lever until you wind back out by 180 degs,if you just wind the piston all the way in, this mechanism is not engaged and the h/brake lever isnt acting upon anything and as ian has found out,you get no h/brake whatsoever.
.this isnt a new discovery,ive known about it for a long time but cant be ar$ed to keep typing the same advice about rear calipers over and over,especially when there are so many
"experts" out there who know better.
Bottom line is if you take the general advice given on forums on fitting rear mr2 pads 9/10 you will have no h/brake or a very poor one as not many people know about the reset method,but this can only be done with the cables slackened off as you would do on any other make of car.
Why is this so important? because it affects the adjustment of the piston.
.and rear brakes are ultra important,if you have a poorly adjusted rear it affects the fronts,set up the rears properly as per my advice and the fronts will improve dramatically.This is done by winding the piston in to a point where when it comes back out 180 it will be a perfect interference fit with the pads ie slightly rubbing when you turn the disc,not binding i hasten to add.
.it takes time and experimenting to get them right,but the golden rule is each time they are wound right in they must be wound out 180 so the trick is to wind in all the way until it goes in no further,position
(A)align the piston holes at 90 degs to the caliper and then wind in say 190-200 degs(B),when its wound out 180(C) it should be very close to a perfect fit,if its not then wind back in to position A and make position B 210 degrees for example until the caliper to pad fit is perfect.
OR! totally ignore the above as most do and continue to fit rear pads as everyone seems to advise and end up with shat brakes.
sorry if im ratty but misinforming keyboard mechanics should stop posting if they dont actually know what they are talking about or simply regurgitating something they read on another misinformed post.
.im off for a lie down.
