ethan wrote:![]()
engine ECU(obviously, although the connector pin-out is almost identical.
Probably the same PCB programmed with different software and with perhaps some components left unpopulated).
Rogue wrote:ethan wrote:![]()
The difference in the ECU is to allow for the chargecooler on the GT4., other than that they are identical.
A Celica ECU will run an MR2, but will only work in safe mode unless something is done to trick it into thinking there's a chargecooler!
Rogue
ethan wrote:not exactly the same apparantly the gt4 has diff part number for:
turbo charger
complete engine assembly(ST205 is 19000-88508, MR2 is 19000-88509)
head sub assembly
short block assembly
intercooler(obviously!)
