spoke to a company today about aem wideband air fuel/lambda gauge kits, i have seen these kits on other uk sites for £275, i can get up to 10 for £225 each all in including delivery and possibly £215 if there is more than 10 peeps interested, let me know if you want one, no maybe's please only peeps who want one.
Product description: Brand new AEM's Wideband UEGO Controller is now available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM's Wideband UEGO Controller feature's an LED readout and sweeping LED "needle" that changes colors as AFR changes from rich to lean. The gauge is completely customizable with optional aluminum bezels and face plates included. User can easily switch between AFR and Lambda readout. A complete easy install wire harness is also included for a painless installation.The unit's 52mm (2 1/16 in.) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Bosch sensor included!
24 Color-coded LED display lights provide immediate reference to engines air/fuel ratio (AFR) or Lambda
Integrated three-digit display reveals AFR or Lambda in real time
User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
Ideal AFR monitoring tool for carbureted applications and engine dynamometers
Does not oscillate AFR like narrow band sensors
Serial data stream included for output of AFR (RS 232)
Accurate to 0.1 AFR
Easy installation!
aem wideband uego controller
Re: aem wideband uego controller
also post on gt4oc so if i can get 5 peeps from each oc might be enough to get them cheaper, the company is in uk so no hidden cost.
The last group buy I saw on these had them up at £169, I can buy them at £199 without the need for a group buy:
http://www.mkivstore.com/index.php?targ ... ct_id=1641
I forgot to say, they will probably run a group buy for you if you ask.
nice one mate, saved me a few ££
No worries, glad to help
