Peter Gidden - sbITs wrote:
I agree with Paul..
Just try my Noble
2.5l V6, 330BHP.
Each T20 turbo is, in theory, matched to a 1250cc engine so small, light, and next to no lag.
Cannon fodder
I agree with Paul..
Just try my Noble
2.5l V6, 330BHP.
PW@Woodsport wrote:good point,actually the TRD set up isnt the best design,its placement means it cant be intercooled..
.now if you were to cram a rotrex under the manifold where the power steering pump used to be and did some clever piping that would produce better results
(after intercooling) than the TRD SC unit.
The benefit of the TRD unit is its compact easy to fit design.
Johnny G wrote:PW@Woodsport wrote:good point,actually the TRD set up isnt the best design,its placement means it cant be intercooled..
But the rotrex is a centrigual supercharger, so it's still got a lag of sorts, does not provide off-idle boost, heats up VERY quickly and has high parasitic losses.Unless you're running mad boost, it's not THAT efficient IIRC.
I know Koenigsegg use it on the CCS or CCX but there are heat issues, they needs large intercoolers
For std applications, roots provides the best off-idle response in low psi regions
