Then, in the confines of the MR2 Mk2, is it possible to fit this in the engine bay
TIA
Rob
mishadbull wrote:I remember seeing someone in the states(via the web) with a Mk2 with a 3.4 L v6 out of a Toyota Tacoma with a set of turbos on it.
It was running too.
Though the video I saw it still had not finalized exhaust and looked a bit tatty
(red if i remember.
) cant remember where those links have gone though.
Mike
PW@Woodsport wrote:yep its entirely do able,the turbo gets remote mounted above the gearbox,actually a supra CT-26a is supposed to work well with the v6,plumbing is a bit of a mare and fancy IC pipes needed..
.id probably stick a large IC in the boot.
SC takes up no extra space as it replaces the stock plenum but it cant be intercooled.
But once you turbo the V6 even low compression it's still going to lack until on boost?
PW@Woodsport wrote:But once you turbo the V6 even low compression it's still going to lack until on boost?
why would it lack until boost came in? you still have the power you had before in NA form only with much more torque throughout the revs by adding a turbo.
This is one of the reasons people go v6,to get rid of that"lacking" period before boost comes in with the 3s-gte.
Just try my Noble
