as above - cos I wanna bend up the bodywork trim (between the exhausts) to show off my news HKS dual super dragger - but the twin back boxes are too big
So... is the flexipipe flexible enough to drop the exhaust down at the back so the trim can be bent up - or will the whole exhaust nee dto come off
thanks
frank
This is something I plan to do v soon.
You'll need to remove the exhaust from the flexi section, (usually a 3 bolt clamp) in order to pull the exhaust away and bend or remove the grill between the exhaust cans.
Not a big job but it does help to have the rear of the car jacked up for improved access though.
