Best oil temp ??
Re: Best oil temp ??
Between 80 and 90 degrees is optimum.
Anything over 110 degrees and it's time to back off
! Also remember that running a car hard when the oil is still cold can cause just as much damage as excessive heat! Try if possible to keep your revs below 3000rpm until you are at least up tp 75 degrees.
Some will say the above is over the top, but if your keen on making your engine last as long as poss, the above will help
Mikejc
Mikejc
I only have the stock dials on my Tubby, i generally run under 3000rpm until the temp guage has reached half way
(where it tends to stay).
I also try and run a few miles off boost and let the engine idle for a minute or so before i switch off.
um.
.anyone else.
.mine runs at an indicated 130 deg all the time
maybee i will fit that oil cooler
What are you using to read the temp? And what oil are you using?
130 degrees is too hot at any rate! Specially considering just how cold things are at the moment
I suggest you have this checked out in some more depth before fitting the oil cooler.
Something is wrong!
As for the stock gauge I take it that you mean the water temp gauge?
That being so, you will find that on some cars these tend to react at different rates.
On my own car this gauge reaches the halfway mark a good few minutes before my oil is up to full running temp.
Just a thought for you
Mikejc
Mikejc
Mikejc wrote:What are you using to read the temp? And what oil are you using?
130 degrees is too hot at any rate! Specially considering just how cold things are at the moment![]()
Something is wrong!
That being so, you will find that on some cars these tend to react at different rates.On my own car this gauge reaches the halfway mark a good few minutes before my oil is up to full running temp.
Mikejc
Yeah mate, my temp gauge gets to half way, way befor my oil is up to temp on the oil temp gauge I have fitted!
Mike
- you are confusing 2 different answers! I use a very thin oil
- 0-5W.
.used it in race engines for quite a while with brill results! Would have thought that if anything this would run cooler??
I was simply asking about the oil used as until now I didn't know.
Mikejc
My car always runs just under half.
hmmmm
hmmmm
axisofunity wrote:My car always runs just under half..
hmmmm
Just means your water temp is spot on.
Small turbos
- they're not big and they're not clever!
Just say NO to small turbos!
Fizzy wrote:Mike- you are confusing 2 different answers! I use a very thin oil
- 0-5W.
Fizz, oil that thin isn't recommended
Remember the oil is sprayed to the underside of the pistons, pulling heat out of the pistons too.
I had mine up to 120 deg C at donny
I noticed with a lighter grade oil, the oil temp did sit circa of 100 degrees C
thanks JJ.
.still seems a bit odd
- its not as though the engine ever runs or even feels hot! probably a poo gauge
- the other question is of course where do you all have the temp sensor???
and dude.
.pleasse.
.its fizzy or just good ol nije!
- are you planning to split anymore hoses this year??
Fizzy wrote:and dude..
.pleasse.
I can tell in your writing its you chap
The probe for mine is directly below the turbo return in the sump, so i can expect fluctuations in oil temp when I start abusing it
I know most use those adapter plates and I'm not sure if they're actually picking up the heat from the block as well
No hoses split of late nige
Still knock about with geoff, havent seen him about either on here.
tHERES A POINT
- MINE IS SCREWED INTO A SANDWICH PLATE JUST BELOW THE FILTER
(OOPS).
.was chattin to chris
- hypersport- about temps and he sees many 2's with 130 deg
!! Well, fitting a remote filter and big cooler this morning
- Geof has lost all interest in his 2 since his last and 3rd blow up
!! I had bits of his turbo all over my car!!!!
(ded funny though).
When my own sensor for the oil temp was in the sandwich plate the oil temp was around 10 degrees higher on average, but still never any higher than 110 degrees even with heavy use.
Take note regarding your oil choice being too thin!
0-5W is simply too thin at both ends!
But rather than me explaining the ins and outs of why, have a little chat with a chap named Guy that i've come to know.
He know's more about oil than anyone i've ever come across and is only too happy to chat all day long about it.
01209-215-164 Ask for Guy
Mikejc
Mikejc
Wait 8 minuits of careful driving before booting it.
thats how long on average the oil takes to warm up.
Again it's hard to say exactly how long it takes for the oil to reach full operating temp as their are many veriables to consider, ie grade of oil, ambiant temp, town driving, motorway driving, idling etc.
On my own car it can take anything from 10-15 minutes
to reach 75 degrees at tis time of year!
Mikejc
Mikejc
