rev1 injectors will flow around 270whp i made 260 whp
(approx330 ish fwhp if you believe engine advantages dyno
one observation i made when changing my injectors to larger ones is the vacum/ boost pipe on the top of the fuel rail
going to the fuel pressure regulator is very small
, and on a spare rail which i have got is practically blocked with oily sludge which goes round the breather system
, this could possibly cause the rising rate regulator not to respond correctly with boost
, but your problems may just be down to a weak fuel pump or faulty fpr
if you are aiming for around 300 fly bhp
(250whp) rev1 injectors will be ok
but i would suggest fitting an uprated fuel pump and maybe an adjustable fuel pressure regulator to give the injectors a bit more fuel
anymore than 250/260 whp and i would have to suggest getting larger injectors, for safety
, which means changing the ems
