Tial wastegate UK??
Andy F
Tial wastegate UK??
Post by Andy F »
Hi all
Doe's anyone k now if there is a supplier in the UK i need a 1 bar wastegate spring??
TBDevelopments
Re: Tial wastegate UK??
Post by TBDevelopments »
Hello bud,
I can get one for you if you need it, will need to import it though which usually takes about a week.
Also what spring do you have already? Also is it a big or little spring fitted already?
The way tial wastegate work is say you have a 0.7bar little spring already fitted, you can go 2 ways either fit a 0.3bar big spring in as well which will give you the option of taking it back out to reset the boost, or you can replace the whole lot with a 1.0bar little spring.
Hope this helps
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:Hello bud,
Hope this helps
Hi Tim
I know what you mean, but i haven't looked, the spring is a 10psi but as to big or little i don't know :roll:
Can you get me a price for a 1 bar big spring.
Andy
Tim
xxxx
MarkP.
Post by MarkP. »
These are dealers for Tial.
http://www.k-tecracing.com/
TBDevelopments
ok cool,
Andy F let me know if you want anything from my guy in the states as i have to bring a 38/40mm red external wastegate over for myself and i'll just get your spring throwning in as well if you want one.
I won't be making anything from this so just pay me cost price :)
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:ok cool,
Tim
xxxx
Cheers Tim
How much mate?????
TBDevelopments
Not that much bud, i get these at about $30-$35 so about £20-£25 max.
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:Not that much bud, i get these at about $30-$35 so about £20-£25 max.
Tim
xxxx
Cool 8)
Will you get me one then Tim?
Its the 46mm WG if there is a differance
Thanks bud
Will you give me a shout when it arrives? or do you need cash first?
Andy
TBDevelopments
i could do with the cash first, i'll just put it through the books like a regular order then.
Also i need to know what size and pressure spring you've got already and what configuration you want to go with then.
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:i could do with the cash first, i'll just put it through the books like a regular order then.
Tim
xxxx
Ok mate.......leave it with me i will take the WG to bits and see whats in there.
When are you wanting to send your order??
TBDevelopments
i'm on no rush mate i'll wait for you :)
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:i'm on no rush mate i'll wait for you :)
Tim
xxxx
Will let you know ASAP :)
TBDevelopments
ok bud
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:ok bud
Tim
xxxx
Ok Tim
I have taken the wastegate off today it has a huge spring inside, so it ius a 10psi big, red spring, i think i will be best getting a 1 bar big red spring?
What do you think??
TBDevelopments
hello mate, can you get me a diameter of the spring. Because i've had small springs before for them and they seem really big, just want to get it right first time. :)
Let me know and i'll sort it asap as i'm ordering my wastegate this week.
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:hello mate, can you get me a diameter of the spring. Because i've had small springs before for them and they seem really big, just want to get it right first time. :)
Tim
xxxx
The diametre is 58mm or 2 1/4
Cheers Tim
TBDevelopments
ok bud.
I'll get a 1bar spring at that diameter for you.
I'll order it tomorrow and let you know when everything arrive :)
Tim
xxxx
Andy F
Post by Andy F »
xxxx wrote:ok bud.
Tim
xxxx
Thats good news mate, let me know what i owe you and your address and i will get a cheque straight off, then if the spring comes early there won't be any delay.
Thanks again
Andy
TBDevelopments
ok bud no problems will let u no asap when it arrives
TBDevelopments
hello andy,
I tried to place the order today but they haven't heard of that size before. That want to know the make and model (size) of the wastegate your trying to use.
If you let me know asap i can get it sorted for you.
Tim
xxxx
