I think your seesaw analogy is flawed.
How I see it, is that by adjusting the ratio of hardness front/rear, you're shifting the axis on which the seesaw pivots, more towards the front and rear.
How my setup currently is, is that the pivot point is more towards the front of the seesaw.
By putting in harder suspension, I'm moving the pivot point back more towards the middle.
Please dont take anything I say the wrong way.
I dont know you, or your background at all, you may very well know better, and/or be far more experienced than me, these are just my thoughts on the matter.
I have an open mind on the topic, I just dont understand your point of view at the moment.
IMO Weight transfer under braking is NOT a good thing.
Although the weight distribution between the four contact points on the track changes, the
inertia
distribution of the car is always equal to the static weight distribution.
Eg.
You have a static weight distribution of 45/55.
When a car spins under braking, it's because there isnt enough rear grip to prevent the inertia of the rear of the car from wanting to overtake the front.
(Unless they were doing something silly)
When you're braking hard, lets say it's 60/40.
Now you've still got 55% of the weight of the car in the back, and only 40% of the cars weight giving grip over the rear to stop the extra inertia from wanting to overtake the front of the car.
If you can stiffen the suspension to lessen this effect, you can brake harder, as you've still got a larger proportion of the grip holding the rear of the car to the ground.
If when braking hard, your nose is ducking down, and the tail is lifting a little, thats' fine.
However with my current setup, the front suspension is significantly harder at the front.
When braking hard, the front resists the weight transfer, but the rear doesnt.
This means that the rear lifts higher than it would otherwise.
Which is definitely bad! The Centre of gravity of the rear of the car gets higher, as opposed to the centre of gravity at the front getting lower.
Now with all of that weight in the back, with less mechanical grip holding it to the ground,
the last thing I want/need is a higher COG there!
Imagine a long pole attached to the centreline of the rear suspension.
when you corner, it's like someone is pushing on the end of this pole sideways, with a force proportional to how fast you are cornering.
If you have a higher COG, it's like having a longer pole.
the same amount of force
(cornering speed/inertia) wants to tip the car over more, without more effort being applied.
This obviously unloads the inside wheel, making it more likely to spin up.
Now on track day, when I had an LSD, was having fun on the hairpin, this was great.
However if I wanted to go faster, I need to lower the COG, keep more weight on the inside wheel, and keep the rear from lifting as much
(and disproportionally to the front) under hard braking.
Now dont get me wrong, my current setup is great on the street, I'd never know the difference otherwise, because you're never going that fast.
But after having a look/think about how my car behaved, I've concluded that harder rear suspension would have made my car more stable on the track.
Now you may very well be more experiencd on the matter than me, and you may very well be right.
But next track day, I'll be going with stiffer rear suspension.
Which may, or may not improve my situation.
But that's the fun of it IMO.
making some changes, seeing how it affects the cars handling etc.
