idling issues - sign of uprated cams?
adamshaw
Post by adamshaw »
If revs start to drop and fluctauat between 1k rpm and 500rpm.
Idle speed control valve changed but still happends, usual HT leads, plugs etc also changed.
Whats this a sign off? Could it be uprated cams?
Will i see any problems? None yet in 15mths?
adamshaw
Re: idling issues - sign of uprated cams?
Post by adamshaw »
any ideas anyone?
dawolf
Post by dawolf »
It sounds to me like it has aftermarket cams on, as long as it doesn't stall I'm sure it's fine mate.
redmr89
Post by redmr89 »
how does the power come on? at what rpm??
my old car did this . spent a fortune on it and never worked out what it was. it wasnt cams tho. i think some cars just do it .
gmtc
Post by gmtc »
could also be caused by old/blocked air filter, blocked fuel filter, dodgy coolant temperature sensor, vacuum leak in the intake system or worn distributer cap and im sure their not the only ones.
If you are still having problems and you've checked all the hoses, i'd also try replacing the distributor cap and rotor arm.
HTH
"There is no spoon"
adamshaw
Post by adamshaw »
Thanks matey,
I have replaced the dizzy cap, rotor arm, air filter and checked for leaks etc...
Nothing all seems sound and boost is bang on!
adamshaw
Post by adamshaw »
Power comes on at about 2600 RPM and can hit max boost just before 4k rpm.
Running ct26 hybrid with T3/4 internals and 52mm compressor wheel. Pulls very good to be honest at 14PSI.
If i put my foot down in first to say 4k rpm and then bang it into second and i virtually on instant boost straight away
Any ideas
