PFC Map for 272 Cams
Stuart
Post by Stuart »
Has anyone got a suitable map for PFC. I need some which is set to run with 272 HKS cams and 800cc injectors.
The stock map runs too rich with injector adjustment... I need to put more miles on the engine before I take it to be mapped. At present the cruise AFR's are all over the place and I’m not happy with driving it on the current map.
If anyone can help me please send me a PM.... I appreciate that people have paid for their map so I’m willing to compensate them if they can supply me with a suitable map.
Stuart
mr_nico_1977
Re: PFC Map for 272 Cams
Post by mr_nico_1977 »
IF you dont have any luck mate I'd recomend contacting the datalogit mail group...
[email protected]
I dont have my power FC or datalogit anymore and dont monitor their files but there are plenty of mr2 owners on there who could probably help...
paul_h
Post by paul_h »
cant ya just do some part throttle mapping stuart, shouldnt be that hard with your wideband.
we finally got pauls running on the aem today, even idles fine with the 264 cams.
need to do some fine tuning now just to get the afr right to put some miles on car, same as you basically.
TBDevelopments
Post by TBDevelopments »
not being funny but with a power fc and those large cams it sounds like you've put some money into your car. why not get them set up properly and tuned to your car instead of trying to use someone elses readings which won't be right for your car anyway. all cars are different even if there modifications are identical
Tim
xxxx
Stuart
Post by Stuart »
Tim,
I would be more than happy to take it to someone to tune but Im not happy driving it with the AFR's it is showing on cruise. Ive been told that the injector Lag may be out.. so Im going to look at what my settings are.
Stuart
TBDevelopments
ah ok, so this is just a mean of getting to the tuners rolling road, i understand now sorry i misunderstood
Tim
xxxx
scoops
Post by scoops »
whack some more fuel in yourself using the test function, that will get you to a tuning place. At cruise your afrs should be pretty steady, even if they are miles out the reading should at least remain fairly constant. What readings are you getting? you havent got the afr probe too near to the turbo have you?
Is it a proper wideband afr or just a crappy narrowband gauge?
Stuart
Post by Stuart »
Dont worry about it Tim... I can understand what you were saying.
Scoops...
Im using an AEM wide band kit with a band new sensor which is located a good distnace from the turbo. I have a feeling that its the injector lag settings which are causing me problems.
Stuart
