si2040 wrote:you have a fault in your electrics pin it and see what it is
Lictor wrote:I had my rev counter jump all over the place when one of the battery leads was barely on the terminal.The power steering takes a lot of current and if the connection can't supply it some strange things do happen.
nailmonkey wrote:Is the CC pump connected to the powersteering circuit?
Nik
Mark Edwards wrote:Mine is wired into the rad fans.
Mark Edwards wrote:It's all in the bgb if you have it.
Mark Edwards wrote:The pump runs constantly, think it's wired into the feed for the passenger side one which might be for the a/c(?)
