Grr Tyres wearing thin on the inside.(245's on an 8inch rim)
Dale_V
Post by Dale_V »
Noticed my Avons have about 1mm on the inside compared to the 3/4mm on the outside of both rear tyres :evil: . They have covered about 13,000 miles so haven't done bad, but whats the problem thats wearing the inside?
Also at the moment I have 225/45/16 on the rear, but would like to go for 245/45/16. First of all will they fit OK?
Second .... I've had a look on http://www.mytyres.co.uk and they have a limited selection (and no AVONS in thats size :cry: ).
so what would be the best option out of these:
- Continental Sport Contact
- Pirelli P-Zero SYSTEM Asimmetrico
- Bridgestone Potenza S02
- Bridgestone Expedia S-01
And third should I stick with my 225's and have a larger choice of tyre (avons) or go for the 245's
:x
User avatar
Lauren
Re: Grr Tyres wearing thin on the inside.(245's on an 8inch rim)
Post by Lauren »
too much negative camber is the most likely culprit.
Dale_V
Post by Dale_V »
Lauren wrote:too much negative camber is the most likely culprit.
Can anything be adjusted to compensate? :?
edit- 225 Avons are costing £75 each... The cheapest 245 out of the above selection is £115 each......
Pete J
Post by Pete J »
Twos r us will be selling a camber abjustment kit in the near future as well as being able to provide on loan, a camber adjustment gauge. Peter estimates it'll be in the shop in a few weeks time.
Dale_V
Post by Dale_V »
Pete J wrote:Twos r us will be selling a camber abjustment kit in the near future as well as being able to provide on loan, a camber adjustment gauge. Peter estimates it'll be in the shop in a few weeks time.
can the camber be adjusted now on the stock set up:?
Pete J
Post by Pete J »
No :(
Andy Jones
Post by Andy Jones »
As Lauren said - I'm in the same boat :(
I get about 5000 miles out of my rears by then the insides are down to the wire :shock: with as you say about 3/4mm left on the outside :evil:
eddy simpson
Post by eddy simpson »
rear wheel alignment needs adjusted
