[Mk2 Turbo] HELP!!!!!!!!!! i think my turbo's fooked!!! :(
ripley-mr2
Post by ripley-mr2 »
now, im no mechanic, i know a fair bit about cars, but i dont realy know anything about turbo's, but i think that mines xxxxx!!!
when i got to where i was going on my dinner time today, as i pulled off the byepass (been thrashing it a bit, however i did alow it to warm up fully before i even drove it, as always) i pulled away from the island and i noticed that my boost guage was reading nearly full boost, but it felt like i was running none at all!!! as i got into the lower gears i noticed that when i put my foot down and got past 2000 rpm it was making a horrible noise, like a banging noise and i wasn't getting boost even though the guage was reading it.
is it bu88ered???
if so, how much would it cost me to get a replacement?? and is there anywere locally to me (derbyshire) that can do it??
please help!!!
Matt
ripley-mr2
Re: [Mk2 Turbo] HELP!!!!!!!!!! i think my turbo's fooked!!! :(
i just got a quote from a company in Manchester of £178 + delivery for a used turbo...is that any good? are they hard to replace??
matt_mr2t
Post by matt_mr2t »
Was it def the turbo making noises?
If you have a rev1/2 and the turbos twatted get a CT20b from a rev3+ car money MUCH better spent?
If the turbo is wasted though you wont make much boost at all so it could be electrical problems?
ripley-mr2
wel, no im not getting any boost. but the guage says that i am. the best way to describe the noise is like the wheel of fortune.
would thats turbo be a direct bolt on or would it require other changes?? how much would it cost to have one of these fitted?
-:[KM]:-
Post by -:[KM]:- »
Where are you this afternoon... could pop up if you want.
ripley-mr2
im just on my way home,my mechanic is a personal friend,so im popping into see him on the way. Just been out in the car and i am getting boost,just not fully,there is no smoke either.it just sounds awfull!someone suggested its probable the bearing thats gone,does this sound likely?
ripley-mr2
i just thought i would let you all know,hue found out the problem n now i wish it was the turbo.crankshaft's gone :-( got a quote of £750 if its fixable. Anyone know if i can get this cheaper anywhere else local to derby? Cheers Matt
Stuart
Post by Stuart »
Matt,
If your crankshaft is gone then its a pretty big job to replace. It is more of a common problem with the Rev 1, 2 engines as the oil pressure relief valve sticks in the oil pump, causing oil starvation at high RPM's. To replace the crank with the engine in the car will require the gear box to be removed.... big PITA. If the crank has gone then it will have been damaged and is best to replace in most cases. You might be able to get away with just replacing the bearings but this is usualy a quick+short fix and wont last if the crank is damaged.
So in total I think £750 isnt too bad a price but that is dependent on what parts are being replaced for that price.
Used crank... expect to pay around £100 (make sure it has been crack tested)
New bearing set approx £85 (Non-Toyota... but can be matched to the crank by any machine shop) Toyota genuine bearings will be around £200+
New oil pump £85 from Mr T
Plus oil and sundries
Expect to pay about £500 labour for all of this... its a big job. Think of it as a clutch change and timing belt plus 3 - 4 hours to replace the crank.
I had a simular problem with a Celica GT4 I owned. The bottom end went and I replaced the bearings... 3 months later it was knocking again. In the end I replaced the engine.
Stuart
k-ro
Post by k-ro »
hi mate, did i come past u friday afternoon on butterley hill?
Kev
Human
Post by Human »
Is your engine light on and have you checked the codes? Its just that your symptoms sound very similar to mine and I have a blown knock sensor....about £100 to replace...worth checking?
ripley-mr2
k-ro wrote:hi mate, did i come past u friday afternoon on butterley hill?
Kev
yeah, very possible, do you live right down next to Lakeside Garage?? i parked it down there, noticed the MR2, then i seen you coming past me up at QES.
human wrote:Is your engine light on and have you checked the codes? Its just that your symptoms sound very similar to mine and I have a blown knock sensor....about £100 to replace...worth checking?
Kev
nope, there are no lights on, how do i check the codes? but yeah it does sound worth checking
k-ro
Post by k-ro »
Thought it was u. dont live down there, was pickin it up, had a new exhaust put on, Bill sed he'd had some guy come down with a blown turbo, which was obviously u!
error codes, u need 2 bridge 2 of the ports in the engine bay, TE1 and somethin else, shud be up in the knowledge base i think.
Kev
ripley-mr2
i'll have a look now.
yeah bill used to do all the work on my Nova...he comes in our pub regular.
what tools do you need for the code reading?
-:[KM]:-
Post by -:[KM]:- »
A paper-clip bent into a U shape!!
ripley-mr2
i cant find anything in the knowledge base, anyone care to give me instructions??? pleeeeeeese??
-:[KM]:-
Post by -:[KM]:- »
k-ro
Post by k-ro »
http://www.off-road.com/toyota/tech/codes/
try that matey
just need a paper clip and count the flashes
ripley-mr2
i have been reading through the guides posted up (cheers keith.mcclorry and K-Ro and i was thinking...even though there is no ECU warning light coming up on the dash, could it still have something to do with it???
also, does anyone know any good garages in the derby/ notts area that can do me the re-build??
cheers Matt
Human
Post by Human »
I live in Derby and from the info posted on this site have decided to go to Rogue Motorsports which is a bit of a trek to Coventry...but its only 30 miles or so!
ripley-mr2
yeah, i have heard good reports of that place, but as i dont want to risk running the car (or at least for not a long distance) and i dont have a means of towing, i would rather find somewhere closer to home.
