Dynoed my mr2 today, 253rwhp *GRAPH ADDED*
Al-sw20
Post by Al-sw20 »
Put my 2 on the dyno today. Came away with 189rwkw or 253 rear wheel hp. Boost peaked at 17.6psi and levelled off at 16psi with fresh airport avgas in the tank, a/f was totally flat when it came onto boost and with an 11.1 a/f, no where near lean. I'll get the dyno scanned up and post it.
Re: Dynoed my mr2 today, 253rwhp *GRAPH ADDED*
253 RWHP!! Very nice mate. My next turbo is going to be a CT20b Hybrid :twisted:
Rikki
Post by Rikki »
Quick question, I "heard" from an Evo lad that AVGAS in Jap imports was a bad idea, he didnt state why though so just wondering what others thought.
Good stuff on the performance run mate!
R.
raptor95GTS
Post by raptor95GTS »
nice figures.
any engine pics? :D
KiwiMR2
Post by KiwiMR2 »
Rikki wrote:Quick question, I "heard" from an Evo lad that AVGAS in Jap imports was a bad idea, he didnt state why though so just wondering what others thought.
R.
CAN burn out your 02 sensor....that's about it :)
KiwiMR2
Al-sw20
Post by Al-sw20 »
Yeah I've got an engine pic.
Behold the standardness :wink:
Al-sw20 wrote:Yeah I've got an engine pic.
and this 253 bhp, is that at the wheels or the fly? If that is at the wheels then you must have more mods than stated on your profile :shock:
Al-sw20
Post by Al-sw20 »
253 hp at the rear wheels. Made peak power at 16psi.
I only have the mods listed.
Al-sw20 wrote:253 hp at the rear wheels. Made peak power at 16psi.
Nice result mate, although isn't 16 PSI a bit too high for a rev 1 engine?
Al-sw20
Post by Al-sw20 »
No like i said it isnt running lean. 11.1:1 a/f. I could run 18psi and it wouldnt have exceeded 12.5:1 resulting in around 270rwhp and the most the stock 440s would be 'safe' for. I do run 18psi at the track with no problems
Al-sw20 wrote:No like i said it isnt running lean. 11.1:1 a/f. I could run 18psi and it wouldnt have exceeded 12.5:1 resulting in around 270rwhp and the most the stock 440s would be 'safe' for. I do run 18psi at the track with no problems
Cool then :thumright:
Jevansio
Post by Jevansio »
My Rev 3 only made 260 with my list of mods :(
JJ
Post by JJ »
It is running out of juice if its heading towards the 12's !!?
Its pulling 10/11's mid range then going to the 12's above 6k ?
11.5 a/r is the tuning norm for keeping things cool... sure its overfuelling, running in the 12's, then the unit starts to gradually get hot.
Okay for the quick stab at the qrt, but a day at the track day will finish a piston off. :shock:
Good result though chap ! I have a friend that managed 270RWBHP too, but he was running water injection too ! :)
JJ
Post by JJ »
Jevansio wrote:My Rev 3 only made 260 with my list of mods :(
Big fellar, you were running pump gas though ! :)
:thumright:
Al-sw20
Post by Al-sw20 »
Theres a peak of boost (17.6psi) around the 4000rpm mark, along with torque and power, then it drops for a second and then picks up again,im assuming this is the tvis butterflies opening and then the profec b compensating and bringing it down to the set 16psi. Boost and a/f are dead flat at 16psi and 11.1 : 1 a/f respectively until redline.
JJ
Post by JJ »
Cool !! but shouldn't you be in bed by now !! :D
Al-sw20
Post by Al-sw20 »
Hhahah yep its like 10 minutes to 2 in the morning :lol:
Jevansio
Post by Jevansio »
:thumright:
Ahhh, I was assuming AVGAS was some sort of low octane NZ stuff, I'm happy now :)
Al-sw20
Post by Al-sw20 »
Yeah it was like 105 octane or something, fresh out of the airport pump ;)
