[mk2 na] clutch recommendations
trd2000mr2
Post by trd2000mr2 »
Tried a search to no avail,
I think my clutch is going so basically looking to change. Has anyone used these EBC clutch kits from funkystyling?? About the same price, if not cheaper, than a standard clutch, but an uprated version...so can't be bad...right? :-k
http://www.funkystyling.co.uk/item_deta ... rodID=1700
Any experiences, advice greatly appreciated!
trd2000mr2
Re: [mk2 na] clutch recommendations
incidentally, since it seems that no-one has used these, what clutches are people running on their na's? Mostly stock? or uprated?
MR2DIE4
Post by MR2DIE4 »
i want to know this too, as i have some plans to tune the engine a little further and also upping the rev limit i could use an uprated item, but don't know yet which one :-k
Matty_GTS
Post by Matty_GTS »
My tubby is running 252 at the wheels, put in a standard clutch and it started to slip after 60 miles to the point where as soon as boost cam up about about 7 psi revs went sky high!!
I went out and got an OS Giken Twin Plate jobbie from Japan.
An overkill i know but one hell of a beast!!
Pics in my garage!
JAP BOY
Post by JAP BOY »
Hi Mate i got a Helix clutch when i had my N/A
MR2DIE4
Post by MR2DIE4 »
that osgiken clutch combo looks nice, thats including a lighter flywheel?
i'm now looking into exedy or spec clutches, does anybody have experience with the TRD clutch ?
Matty_GTS
Post by Matty_GTS »
Flywheel built in
trd2000mr2
hi mate,
Similarly to myself, you're probably going to experience troubles trying to find a good uprated clutch for the na. In the end Ive settled for the EBC item, not exactly uprated, but will be enough to handle the power of an na. Will let u know how it launches when i get it fitted this saturday
MR2DIE4
Post by MR2DIE4 »
ok
maybe i'll go for a custom setup then (stock clutch with stiffer springs and reworked clutch plate)
shane1978
Post by shane1978 »
Didn't rate the EBC clutch had it two years 30,000 miles to go completely.
I really must drive hard! (didn't think i did!)
TBDevelopments
Post by TBDevelopments »
RPS Clutches all the way, we've had nothing bud good things with them
Let me know what spec and power rating you want and i'm sure i can provide you with something.
Tim
xxxx
Leon.
Post by Leon. »
For an N/A you're never going to have slipping problems with the standard clutch, even if you throw a V6 in it!!
Just be aware of stiffer and less comfortable clutches when going aftermarket, not to mention additional noises etc.
I'd go standard myself, unless you do lots of traffic light gps and want to drop the clutch at 6k.
