how to prop up your mr2?
Hurstie1981
Post by Hurstie1981 »
Hello,
Just a quick one. When using a jack to lift up my two, i use just an ordinary trolley jack and use the correct jacking points. I want to be able to remove the jack leaving the car raised, incase some idiot thinks it would be funny to lower it with a wheel missing, damaging the car. A, whats the best thing to prop it up with, and where abouts should it/they be positioned?
Graham
Fonzy
Re: how to prop up your mr2?
Post by Fonzy »
Buy some axle stands form halfraud, bout 10 quid i think jack up your car using the sub frame as jacking point position axe stands under jacking point either side just bit further back the the rear joint of the doors, lower car onto stands! :wink:
Hurstie1981
Thanks!! I jack it usually where the notches are,.....i was just wondering if its safe to use the stands there
Fonzy
Post by Fonzy »
i had mine sat on stands for a year! all kinds of wheather and various conditions, stands are the way to go for safety sake!
Hurstie1981
Hmmm, what about just propping one side up? Ive refurbed the nearside wheels, and want to do the offside ones, and i could do them both at the same time.....?
Fonzy
Post by Fonzy »
you can but i would have thought its better to do the front then back or the other way round, i never like the look of a car on its side although im sure it would be fine.
Hurstie1981
Hmmm, ill see what i can do, ill probably get two set of axle stands! So if i jack up at the usual points, and place the stands a couple of inches away it would be no problem?
Fonzy
Post by Fonzy »
exactly! good luck!
Hurstie1981
cheers!
michael
Post by michael »
Hurstie1981
Cheers Michael, youre a good man! Did you get my pm?
michael
Post by michael »
Hurstie1981 wrote:Cheers Michael, youre a good man! Did you get my pm?
Did you send it last night? Had a few beers and remember a pop up but then for some reason I deleted all my PMs... can you resend it?
Hurstie1981
Yeah no probs!
User avatar
Lauren
Post by Lauren »
A small tip here but whenever i want to work on the rear of my car i jack it up at the rear gearbox to chassis mount as its fairly low, then jack the car up in the air and put an axle stand under each rear sill jacking point.
If you do it that way, not only is it quicker you get round the problem of the jack being too close to the axle stand.
Hurstie1981
Good tip, id be scraed of my car roling over though lol! :)
User avatar
Lauren
Post by Lauren »
Hurstie1981 wrote:Good tip, id be scraed of my car roling over though lol! :)
LOL, well it will tend to tilt a little toward the O/side as it goes up because of the engine being heavier than the gearbox.
That said its not a problem. For some reason on my MK1 when the jack won't go any higher i can easily get the axle stand under the n/side but for the o/side i normally get Mark just to lift it a fraction under the wheel arch and slot the o/side axle stand in.
I've done it like this thousands of times, with no problem, honest!
Hurstie1981
Must be a dud car if youve had to jack it up that many times :P
User avatar
Lauren
Post by Lauren »
That'll be a dud 4 cars then! I've just done a lot of work on my cars over the years, swopping engines, i do everything myself. New car will be straight up on the stands next week as i need to sort the brakes and swop the suspenders over.
Hurstie1981
hehe, only playing with you!
I wish i was that handy with cars, can just about top up the windscreen washer bottle!
MegatronUK
Post by MegatronUK »
Its much easier to press a button to lift it up :lol:
