On my rev 2 turbo how can i tell if it has a limited slip diff? Is there anything on the dashboard to look out for or anything mechanical?
Thanks.
mushky wrote:Apparently you can test it yourself if you can find a big bit of empty road.Put full steering lock on, rev to about 4K and then drop the clutch.
If it spins you right round then you have an LSD.
Haven't tried it myself yet.
Note..
The stock Toyota'Viscous' LSD is poo!
Sanchi
Who are you getting to do the insurance on your N/A MR2 with the turbo engine transplant? I would have thought that the premium would be at least as high if not higher then insuring a stock MR2 turbo anyway???
Sanchi wrote:Sanchi
Hey speedtwelve,
im gonna be a bit of a naughty boy and not tell the insurance company of the transplant just yet!![]()
At the time when you're mostly likely to stack it with one of the most obvious mods you could make you choose not to tell them.![]()
