dash light bulb sizes
nitric4k
Post by nitric4k »
ok im thinking of changing the colour of my dash at night i seen ebay want 25quid for about 6 bulbs.
but im going buy from ultraled instead, just wondring if anyone can tell me what size bulbs are where?
im probably going replace clock bulbs, the ones on the roof ashtray bulb lighter bulb, ignition key bulb
then later on attempt the heaters bulbs but i understand these have to be soldered?
ChrisW
Re: dash light bulb sizes
Post by ChrisW »
For the dials - 4 x 501. There's another 501 for the fuel light, but when I replaced it with an LED it seemed to illumuniate slightly all the time, so I went back to the standard bulb :-k
Cig lighter - this is a weird Toyota bulb. Maybe an LED could be soldered in its place?
Ashtray and ignition - both 286 type bulbs I think.
Roof - not sure, probably BA9?
nitric4k
Post by nitric4k »
your sure there 501 for the dial lights? there the same as the side lights at the front if i remember right.
cheers m8
k-ro
Post by k-ro »
yep. ill second that for ya. deffo 501 bulbs
ChrisW
Post by ChrisW »
Yes that's right, same size as the sidelights. Probably a lower wattage though.
nitric4k
Post by nitric4k »
im looking on ultraleds now and im really really confused there is so many 501 size bulbs. which ones work best or which ones did you guys use??
ChrisW
Post by ChrisW »
The ones I've got were called "White Ultra Bright Frosted Bulb" but they don't seem to be on the site any more. They're not great anyway, they look a bit blue and don't illuminate the dials evenly. The "wide angle" bulbs would probably be better.
I also bought "White Xenon 6 Super Bright Leds (Two Bulbs) Wide (VR Ver)" for the sidelights. They're good, but they're so white that they make the headlights look very yellow - gonna have to get a HID conversion now! #-o
Paul F
Post by Paul F »
I have just done this on my dash and I bought these:
Dash:
http://www.ultraleds.co.uk/product_info ... e635a2b2bf
Ashtray and Ignition ring:
Interior:
(Need brighter ones for this tho)
I would do some pictures of the dash but one bulb appears not to be working #-o
THT
nitric4k
Post by nitric4k »
which did you buy for the fag lighter bulb?
how do do we fit these by the way, do i have rip the dial faces off carefully :)
i had a bit of a practice on the mr2 im breaking only way i could see was to rip the dial faces off
ChrisW
Post by ChrisW »
No need to rip the dials off! The bulbs are in black twist-fit holders on the back of the dial cluster.
There's a useful picture on this link:
http://www.mr2oc.co.uk/index.php?name=F ... ic&t=28468
Paul F
Post by Paul F »
Like ChrisW said they are twist locks on the back of the dial cluster. As for the fag lighter I have not attempted that yet however it looks like I will have to de-solder the old bulb and put a new one in its place.
nitric4k
Post by nitric4k »
cheers, ive had everything unscrewed before but ive never been able to pull the clusters out in one peice its always felt like there is somthing else holding it in??
ChrisW
Post by ChrisW »
You can't pull it out very far without disconnecting the plugs round the back. It can also be quite awkward to manoeuvre it over the steering column. And did you remember to remove the black trim that sits in front of the top edge?
I'm sure I've seen a good how-to with photos somewhere. :-k
Paul F
Post by Paul F »
There is a full photo guide on mr2oc.co.uk in there guides section under the guide "How to replace the stock dials with Electro illuminescent (EL) versions".
k-ro
Post by k-ro »
for the cig lighter bulb, iv got sum quality street wrappers to cover the original bulb! gonna do it sunday so ill let u know how it looks! already got a blue led for the ignition ring that looks cool, so we'll see if they match up! :?
JustJJ
Post by JustJJ »
Well I replaced the bulbs in my Dash.... its very very easy...
I originally put some new blue 501s in there... but they have gone very manky very quickly.... so I have opted for LEDs...
I put a write-up on TOC... and a couple of pictures.... will post below if its useful...
Piccies:
1) Take a phillips screwdriver into the car with you and go sit in the drivers seat (you can do everything from here lol)..
2) Pull off the gear gaiter (not all the way, just off its surround) and take out the plastic surround bit from underneath (being careful if your clifford / alarm LEDs are fixed there)... put the placcy bit out of the way somewhere.
3) Take out the ashtray, if you are like me and have those cute airfreshener balls in it, dont spill them all over the car... lol (I didnt... phew... but one or two have gone walkabout before lol)
4) There are two screws located behind the ashtray, undo these and put them somewhere safe!
5) under where the cig lighter is, there is another screw, undo this and put it somewhere safe.
6) To the right and under the ignition is another screw, undo this and put it somewhere safe.... safe... ok?... you dont wanna be losing these lol...
7) Pull the lower part of the dash (bit that goes around under the steering wheel down (this will free off the upper bit somewhat)
8 ) pull out the placcy surround which goes around the radio etc... careful of the vents... and also when you come to the wires connected to the hazards button and the back of the cig lighter... take these out carefully making sure you dont lose any bits in the process
9) Now that large bit of plastic is out of the way, you will find there is a screw just to the right of the steering wheel... undo that... and put it somewhere safe...
10) this enables you to take off the placcy bit that goes over the steering wheel and encompasses the vent on the right. be careful with the vents again.
11) Yay another bit of dash out of the way lol... ok now.. if you look at your dials... top left and top right either side there is a screw! Guess what? undo them and put em somewhere safe lol..
12) this will free up the little plastic strip that goes over the top of the dials.... put it with the rest of the plastic you stripped.
13) Right.... now you should be able to pull out the dials, being careful to manuever them around the steering wheel... they are connected at the back with 3 large connectors(well it was in mine), careful when you unclip these, they can be a bit of a pain...and dig into your fingers!...
14) Dials are now free and hopefully sat in your lap lol... turn them over and you will see the backs of the black bulb holders, as dave said, the four biggest ones across the middle of the back of the dials are the ones to replace (I think the fuel light is off to one side a bit.. and possibly a little bit smaller... cant remember)....
15) pull out what is in there, and pop in your LEDs... LEDs have polarity, so once you have replaced all current bulbs with LEDs pop the dials back into their slot and attach the wires, before turning headlights on to check that they all work!!
16) Once they all work...do steps 13-1 lol...
And best of luck anyone who is gonna do it... its really quite quick, especially once you done it a couple of times... I am deffo not a pro and it didnt take me long... just remember the order everything went in, and make sure you dont lose any bits of dash (the plastic strip above the dials often gets forgotten .... lol oops)... and dont lose any screws!!! :D
Have fun!
Enjoy! :wink: :thumleft: :thumleft:
Return to “Electrical”
