I am using an Extreme kit.
The only part of the mr2 that is still visible is the glass and the roof skin.
This is considered the best kit available
& the panels were moulded from a genuine car.
There are some mods to allow it to fit onto the mr2 such as the slightly longer tail behind the rear wheel and the screen shape but otherwise its exactly as enzo intended it.
The lights are moved forward but full brackets and mounts are provided making it one of the simpler jobs in the build.
I have been in the kit car scene for about 10 years now
& its the kits that bring me to the mr2
/ 406coupe etc not the other way around.
I know exactly which areas need attention
& where you can get away with standard toyota.
Like I said 19's on a standard mr2 could suggest a max power type car.
19's on a ferrari replica do not look out of place.
The standard 18's are the very minimum that should be fitted and 17's just dont look right.
Many of the genuines are putting 20's on
& they look perfectly reasonable.
I just want a slightly larger than genuine look
& the 19's are only 1" larger than the ferrari 18s.
I will let you decide when its finished.
Like I said before, dont humour me, tell me exactly what you think.
BUt wait until you actually see it
- dont assume
& group the extreme kit with some of the sh1te half ar$ed kits that are out there.
Just getting back to the topic, did jonno actually re-weld the original spring seats onto the shock body or did he weld a spacer and a fresh spring seat above the original? I thought that welding to the shock body would knacker the shock??
