Now this is an intercooler
robsgts
Re: Now this is an intercooler
Post by robsgts »
what the f@cks goin on here , how come theAFM is in the intercooler pipes?hows it supposed to measure the air coming in? and wheres the fookin air filter ?
looks funny to me :-k
rob
Driftlimits Performance
IMOC Affiliated Company
This is the exstract from which the picture was taken hence "3S-GE" Not GTE!
Remember which way the Japanese read text mate :whistle:
THE DUKE
Post by THE DUKE »
NA's Dont have AFM's like that
NA's Dont Need intercoolers
NA's Dont have pipework going to a turbo!!
NA's Dont have surge tanks
Defo a Turbo \:D/
aaronjb
Post by aaronjb »
robsgts wrote:what the f@cks goin on here , how come theAFM is in the intercooler pipes?hows it supposed to measure the air coming in? and wheres the fookin air filter ?
The air filter will be wherever the air enters the system prior to the turbo..
The AFM doesn't care about the air entering the system - all you really care about is the air entering the engine (so in reality it can do that by being placed anywhere in the intake. After the air filter, after the turbo, after the intercooler, just so long as it's before the throttle plate).
In fact, you can argue that you get a better reading of the real air (including post-turbo-heating density) entering the engine with the MAF post-turbo. Most of the current breed of Mk3 turbo kits are like this.
vipernet55 wrote:So whats to stop me running the airflow meter after my TD06?
Nothing - just bear in mind that you'll need a standalone or mappable ECU capable of being mapped, since the airflow characteristics will be wildly different with the MAF post turbo compared to pre turbo. If you just move the MAF you'll likely get horrible detonation if you don't change the tune.
You're getting a better idea of the air volume entering the cylinder with the MAF post turbo. Another side effect is that if the MAF includes an air-temperature sensor (I don't know if the Mk2 does, the Mk3 certainly does) then you get accurate air temperature readings so the ECU can do proper air-temp fuelling & timing corrections.
Adam J
Post by Adam J »
The whole page is on the 3s-ge and i cant get a good enough picture but there is some txt at the bottom of the picture that also says 3sge and on the previous page it talks about the 3sGTE which also has a picture of another car...Turbo Car not Normally aspirated!
I have that very magazine.
Harry
beano
Post by Harry »
:study: beano... :whistle: \:D/ 8) :) :D
