what sort of power gains am i likely to get?? ive a rev2 gts tubby, only aftermarket performance part is my toms exhaust
obviously if i set it to 15psi, what could i increase by??
jimGTS wrote:ive got a boost gauge to install, and plan to get these 2 other parts when the weathers a bit better.
what sort of power gains am i likely to get?? ive a rev2 gts tubby, only aftermarket performance part is my toms exhaust(i think, lol).
BenF wrote:jimGTS wrote:ive got a boost gauge to install, and plan to get these 2 other parts when the weathers a bit better.
Hmm, rule of thumb is1 extra psi
= 10 extra hp.
But remember turning up the boost will only expose any exisiting faults and make them more obvious- and you may also need to wind back your timing a little to make sure you don't pick up detonation, even if you're using super unleaded.
= 10 extra hp.
The Morris wrote:BenF wrote:jimGTS wrote:ive got a boost gauge to install, and plan to get these 2 other parts when the weathers a bit better.
= 10 extra hp.
Are you sure? So if you increase a rev 2 from 7 psi to 15 psi you will get 80bhp, that wil make them 300bhp with just that mod
steve b wrote:the 10 bhp thing is fiction, at least on rev1& 2's
at 1 bar with no other mods it'll prob get 235bhp but torque will go up to about 250lbs
jimGTS wrote:BenF wrote:jimGTS wrote:ive got a boost gauge to install, and plan to get these 2 other parts when the weathers a bit better.
= 10 extra hp.
could the timing be done at millway??
= 10 extra hp.
where did you get 7psi from mate.
standard rev1/2 go to 10-11psi.
(there limited from 5-8psi in 1st and 2nd gear though).
thelegend wrote:i remember the days when people used to make 265hp with a decat, exhaust, filter and 1 bar.What happened?
I belive Canny ran 267bhp on his rev 1?
GTSChris ran up to 278 i belive on his rev 2.
i think some cars run bad too as quatermile times have proved.
How come some rev1+2's run mid 13's down the quatermile yet some only scrap mid-low 14's with the same mods.
Ignition components maybe?
Just a thought
lee
jimGTS wrote:what exactly is a decate???
is it a part, or a modification of a standard part i already have on the car?????
steve b wrote:jimGTS wrote:what exactly is a decate???
decat= remove the catalitic convertor
see downpipes
