I know a couple of people were interested in this powered under-seat sub, and I've just finished fitting mine in the mk1.5.
The unit itself is a very solid piece of kit, all cast alluminium body
(not plastic as it appears in the images on the web) with a flippin' heavy speaker inside! The wiring is via a fly lead with twin phono's, earth, remote and 12v multi plug that attaches somewhere within the inner confines of the sub that you cant get to
- so if you damage the fly lead or have to cut it; be warned! It also comes with speaker to phono leads if your head unit doesn't have line out or subwoofer out phono connections.
It's pretty loud, surprisingly so for its size, has adjustable gain and high pass filters and is selectable between normal and reverse phase.
Not a bad sounding bit of kit
- easily worth the
£95 from caraudiosecurity.com
- and definitely fills out the bottom end of the sound in the mk1 where we are limited to 4" speakers.
It
*just* fits under the standard mk1 seats mind you.
so if you've got lower ones you're stuffed.
and you may not get the seat all the way back either
(it needs a bit of effort to get past the sub as it
just
catches underneath)
- my passenger side seat is now 1-1.5" from the back, as it won't go any further.
Johns verdict? Two thumbs up!
