Fitted new wheels
KrisB
Fitted new wheels
Post by KrisB »
What do you reckon of my new wheels ?
before
after
im happy with the way they look \:D/
Goldy
Re: Fitted new wheels
Post by Goldy »
Looks good mate.... a fair improvement!! Good choice =D> What wheels are they?
Looks nice mate! I'll move this to the member profile area.
Cheers.
ross2
Post by ross2 »
Lovely wheels mate really suit the car :)
KrisB
Post by KrisB »
The wheels are rota boosts in 17`s
MikeyG
Post by MikeyG »
Looks great! I have gold Boosts on my black Rev3 tho so Im a bit biased! ;)
BigBoyNinja12
Post by BigBoyNinja12 »
Very nice indeed.....
Fitment advice......Are they the 17x8 with 35 offset, or the 17 x7.5 with 45 offset?
Have you used spacers?
And are you getting any rubbage at all?
BBN12
Quigonjay
Post by Quigonjay »
MikeyG wrote:Looks great! I have gold Boosts on my black Rev3 tho so Im a bit biased! ;)
you have a pic mate? am considering these so would like to see what they look like on a black car :)
EDIT: Nm, spotted your thread :wink:
are yours the staggered ones? :-k
Quigonjay
Post by Quigonjay »
BigBoyNinja12 wrote:Very nice indeed.....
BBN12
^^^what he said^^^
staggered set up :?:
do you have a pic from the front corner to see how flush they sit with the arches?
sweet rims btw :wink:
MikeyG
Post by MikeyG »
Mine are staggered yes. 17x8 on the back and 17x7.5 on the front. Mine rubbed on the front strut as I have some aftermarked Jap suspension set up so I have used 5mm spacers on the front.
Spittinflames
Post by Spittinflames »
I really really do like the wheels..... good choice. =D>
Quigonjay
Post by Quigonjay »
MikeyG wrote:Mine are staggered yes. 17x8 on the back and 17x7.5 on the front. Mine rubbed on the front strut as I have some aftermarked Jap suspension set up so I have used 5mm spacers on the front.
what size tyres?
you too krisb? tyre sizes :?: :eye:
getting really tempted by some of these in gunmetal (almost black)
MikeyG
Post by MikeyG »
I think mine are 215/40/17 tyres on the front and 235/40/17 on the rear.
Go for it mate they look really nice in the flesh and Gunmetal is a bit different also.
KrisB
Post by KrisB »
tyre sizes are 215/40/17 front on 7.7 inch rim and 245/35/17 on 8 inch rime tyres are falkens( were on speacial )
front are close and sit in a little think going to get some 5mm spacers MickeyG- where did you get yours from ?
MikeyG
Post by MikeyG »
Got mine from Powerhouse in Derby but I think they have caused some vibration through the steering wheel. May get some more expensive ones later. I think Eibach make good ones.
Andy Jones
Post by Andy Jones »
Do like the Boost on the 2 =D> Shame the 7.5j isn't available et35-38 to fit better with aftermarket suspension :(
MikeyG wrote:Got mine from Powerhouse in Derby but I think they have caused some vibration through the steering wheel. May get some more expensive ones later. I think Eibach make good ones.
If the vibration only started when you put the 5mm spacers on chances are the wheel/spigot ring is no longer sat on the hub and the wheel studs are taking the weight of the car - Problem with the 2 (and the majority of Jap cars) they don't have a very generous hub (doesn't matter with stock alloys) but becomes a problem when you start using non-hubcentric spacers with aftermarket stuff. 3mm spacers are usually fine (depends on the taper on the spigot ring if fitted) but i've previously tried 5mm on mine a while back to try and space out the rears but didn't bother as the spacer meant the spigot ring in the back of the wheel was no longer sat on the rear hub properly and i only got 3 full turns an the wheel nuts - Not advisable to be honest if this is the case, Worst case scenario is snapped wheel studs and wheel falling off :(
Engine rebuilt by: Steve Horrocks & Andy Jones
Engine mapped by: Ryan@2bartuning (330 bhp & 325 lbft @ 1.4 bar)
Current Status: F****D :(
