Limeymk1 wrote:The engine weight gained from the work done will probably be about the same as the weight lost from removing the A/C.
That doesn't sound too bad! You'll have to get it on the weighbridge when it's ready Toni.
Basically the SC will operate to a given rpm then will be disengaged at the point the turbo has spooled up, so they won't run together so as to speak but obviously there is always overlap as the turbo builds up pressure.IIRC there is a valve that operates in the induction piping that gets around the problem of both blowers working against each other.
tonigmr2 wrote:Oh and thanks for the comment on the colour guys, what can I say but something else is planned there to!
T
