cheers.
Peter Gidden - sbITs wrote:Ummm, unless i've been awake far too long, these are differences Rev1/2 to Rev3..
Whats this about the pipe coming off the throttle body?
Well I have one that kinda goes in a loop if that makes sense.![]()
JJ wrote:SO we've agreed on:
Rev 1 to Rev 2 Turbo:
Chassis& Interior
Deeper front air dam
Honeycomb plastic between the rear lights changed its design slightly..
more boardering.
15" Wheels
White fog lamps as standard
Bilsteins as standard with stiffer lowered springs
Longer track control arms to the rear
Bigger brakes all round
Different steering wheel( less bulky 3 spoke
Shortened gearknob
Tweeter covers are meshed
Larger door speakers used 6.1/2"
Alcantara seats tougher on the GTS models
Running gear
Dual/ Triple syncro gearbox used as earlier ones were like chocolate.
5mm HT leads used, different coil pack
Throttle body adapter plate changed( option of TRAC
Throttle body changed- geared down
- reduce snap open throttle on light throttle.
Cam cover partially different( throttle section holding down points
Charcoal canister different
Vac hoses to charcoal canister( 2 on rev 2
Intake manifold support bar adopted
Head partially different- Exhaust manifold gone from 7 bolt to 9 bolt
( common problems of warping
/ cracking
Stainless steel piping network around engine( prone to corroding on rev 1s
Block coolant take off nozzle increased diameter
Temp Gauge sensor connection different- gone from spade to connector
ECU is different
Engine harness is different
and thats all I can think of for the time being!
