Mini Cooper SC
Mini Cooper SC
I have a mk1 sc and wanted to know if there is any performance reason to replace it with the mini sc?
(good upgrade over stock maybe)
Re: Mini Cooper SC
The reason for the question is Fensport do the later Levin type(increase by 12hp)
It has an HKS pulley which takes upto 10psi.
- Lauren
- IMOC Committee
Re: Mini Cooper SC
don't bother with the HKS pulley, waste of time.
Just go straight for the fensport pulley.
I had the setup you are talking about on a levin engine.
Worked pretty well.
think it will be a lot of hassle to fit a mini SC.
Would be interested in seeing it done, its question of making a bracket up I guess and sorting out pipework of course.
2020 GR Yaris
- Circuit Pack
Re: Mini Cooper SC
I did look at the fensport pulley 12-14psi apparently.
May do that as a future mod money willing.
I wanted to sort the cooling out first(intercooler, spal fan, possibly an oil cooler, some hideous air intake
Have you ever used exhaust rap, the label say 50% heat reduction in engine bay and can you use is on a stock manifold, and while im thinking of it TRD thermostats open at 70 degs is this good?
GASP.
Finished
GASP.
Finished
Re: Mini Cooper SC
LeeHoochie wrote:I did look at the fensport pulley 12-14psi apparently.May do that as a future mod money willing.
Mine makes about 12.5psi
Don't bother with a fan on the intercooler
If/when you fit a larger pulley, don't forget to do the ABV mod
Re: Mini Cooper SC
LeeHoochie wrote:I have a mk1 sc and wanted to know if there is any performance reason to replace it with the mini sc?(good upgrade over stock maybe)
Although the Mini supercharger is of a better/more efficient design it is still a fixed displacement supercharger.
Re: Mini Cooper SC
sounds like i should be happy with what ive got, I could stick a tractor wheel to the crank and a pram wheel to the sc.
could be interesting
Re: Mini Cooper SC
Lee, if yours is standard, simply fit a Fensport pulley and make sure the standard intercooler is working to its maximum efficiency.
You'll be surprised how good the results are!
(I was
Re: Mini Cooper SC
Icsunonove wrote:It would be difficult to fit though Alex, wouldn't it?..
actually not that difficult.
http://media-icon.co.uk/
- Lauren
- IMOC Committee
Re: Mini Cooper SC
GASP..
Finished
Don't bother with a fan under the intercooler, tis a waste of time.
Do you do trackdays? If not i'd say i wouldn't overly worry about increasing the cooling capacity as its not such an issue on teh road really.
Also don't do the crappy ABV mod as described on various sites like mr2sc.com.
In fact i'm just enquiring into getting a load of SC outlet pipes that do away with the ABV made up for the SC list like i had on my car a couple of years ago:
Other details of my ducting here:
If you want an oil cooler get one off an NA, you will need the sump, oil filter bracket adn pipework too.
2020 GR Yaris
- Circuit Pack
Re: Mini Cooper SC
AlexE wrote:Icsunonove wrote:It would be difficult to fit though Alex, wouldn't it?..
actually not that difficult..
.does require a different intake manifold though.
.you can see further details of the NA 4ag we put an Mercedes/Eaton SC on here:
(the car is no longer owned by my friend but the details on this website are a re jig of his original build notes, oh and please note its a Lotus 7 type kit car not a AW11 but I'm sure a similar setup would fit in a MK1)
Are you saying that you superchacharged a NA 4-AGE rather than a 4-AGZE?
Jon
Re: Mini Cooper SC
j0nathan wrote:
Are you saying that you superchacharged a NA 4-AGE rather than a 4-AGZE?![]()
Jon
Jon, yes thats it.
Re: Mini Cooper SC
Alex, you've got me really interested now!
And a 4-AGE engine with 6 psi boost would be quick in a roller skate
/ Caterfield clone.
Is 6 psi the recommended maximum boost using standard 4-AGE pistons and Megasquirt? Or was it simply a case of that's what it produced with the standard 4-AGE pulley?
Can Megasquirt take inputs from the 4-AGZE knock sensor? and knock back the ignition timing?
Re: Mini Cooper SC
Icsunonove wrote:Alex, you've got me really interested now!![]()
And a 4-AGE engine with 6 psi boost would be quick in a roller skate/ Caterfield clone.
the 6 psi we ended up with was to be honest a bit of a hit and miss affair.
As for the megasquit and the 4agz knock sensor.
Re: Mini Cooper SC
Lauren wrote:
If you want an oil cooler get one off an NA, you will need the sump, oil filter bracket adn pipework too.Find someone who is scrapping an NA and grab all the stuff, reckon you could get it pretty cheaply tbh.
Its a good design as its a water oil cooler and is well out of harms way plus is fairly indestructible.
Ive actually got an old mk1 n/a sitting on my drive way(being used to give a s/c a better life
I thought the s/c had the same oil cooler
Also, as im new to the would of s/c's
- Lauren
- IMOC Committee
Re: Mini Cooper SC
Ive actually got an old mk1 n/a sitting on my drive way(being used to give a s/c a better life![]()
I thought the s/c had the same oil cooler(I haven't actually looked to be fair)
Also, as im new to the would of s/c's"whats an ABV
The SC does not have an oil cooler.
ABV is basically a valve that bleeds off excess boost over 8psi back to the inlet on the non-pressurised part of it.
The only solution is to remove the ABV entirely as that way you can ensure all boost generated by the SC goes to the engine.
2020 GR Yaris
- Circuit Pack
Re: Mini Cooper SC
Lauren
- if you remove the ABV how does the engine breathe when the SC isn't running
? Apart from its function of controlling max boost under ECU control
( which is disabled by the mod detailed here http://www.mr2sc.com/websites/tech/abvlines.htm
), it opens to bypass the SC when it isn't engaged allowing air to pass straight between the throttle and the inlet manifold.
Re: Mini Cooper SC
I'll start working on removing the said items at the weekend
I reserve judgement on the ABV mod once you've discussed it a bit
Cheers for the advice so far
