RE: chargecooler power.
costelg
Post by costelg »
Where excactly do you guys get the 12v from to power the waterpump for the chargecooler. I am researching this at the moment?
94 GTS
gmtc
Re: RE: chargecooler power.
Post by gmtc »
The black wire with red stripes in the engine fuse box. These are switched and so the pump will automatically start up with the ingnition key.
"There is no spoon"
Rory
Post by Rory »
My pump is powered from the power steering pump at the front of the car.
Rory
My MR2 for sale! Check out the for sale section
Mark Edwards
Post by Mark Edwards »
Engine rad fans for mine.
xxxx, AM TUNING, sbITs
mr2turbo117
Post by mr2turbo117 »
here is what pace say to ge the power.
not sure if correct as i have not fitted my yet.
hth
"Connect water pump top electrical supply to grey wire on boot "
skinthespin
Post by skinthespin »
I removed the foglights on mine, so used the circuit for that, what this means is its fully fused on its own, plus the foglight warning will go out on the dash if the pump packs up for any reason, so will give me a bit of a warning.
