Hi guyz what will cause my NA to have bad fuel economy before any one says lamba sensor ive checked with toyota it hasn't hgot one which are the other usuall suspect in this case then!
All help aprriciated
Make sure ignition timing is OK and that plugs leads dizzy cap and rotor arm are all in good shape.
Otherwise make sure the clutch isn't slipping and that the beakes aren't binding.
Noi haven't mate to be honest im not too sure how to do that it has been mentioned but i dnt no how to check for codes !i was going to change it and see isf that made a difference
Or http://www.off-road.com/toyota/tech/codes/
Really easy. Your diagnostic plug is in the engine bay. Its on the drivers side on the back wall. All you need is a straightened out paper clip ro a short piece of wire with both ends bared.
