Front axle 530kg
Rear axle 720kg
Gross 1250kg
JJ wrote:So assuming you have around 280bhp, thats: 224bhp per tonne
Nice colour by the way!!
Al-sw20 wrote:This is why I attain such good results down the 1/4 mile in my gen1 turbo.I weighed mine in at our local tip and it was 1220kgs with no fuel.
steve b wrote:[
ah you can loose 20kg easy still though, as fuel is 1kg per litre, 35? or is it 40 litre per tank so+ 37ishKg put it as 1257kg with full fluids
Lauren wrote:steve b wrote:[
Fuel is actually a bit less than 1kg per litre.So 41 litres weighs in at around 30Kg.
steve b wrote:Al-sw20 wrote:This is why I attain such good results down the 1/4 mile in my gen1 turbo.I weighed mine in at our local tip and it was 1220kgs with no fuel.
for those that don't know, my car weight related spec is as follows:-
single exit exhaust(in my opinion the biggest saving)
1 exhaust mount removed
exhaust heat shielding removed
subframe resonance block removed
boot lining removed
rev3 spoiler
bulkhead heat shielding removed, replaced with thermotec barrier
stock induction removed
engine cover inner panel cut away
electric aerial removed(in-car one fitted)
No centre console box
No spare wheel(replaced with can of puncture repair stuff
& pump)
No spare wheel frame
No plastic cowl under bonnet
No air con
No ABS
Sunroof oppose T-Bar
Coilover suspension
Rays 16" lightweight split rims
