What was the upgrade done to it
Rob
rwilson_ie wrote:Basically, you're saying- Size Matters
rwilson_ie wrote:
But what I didn't fully follow was your conclusion about the external wastegate?
I'm not a turbo tecchie but is the advantage of the external wastegate that it leaves more room for a bigger housing
Fats wrote:Alright mate, it has a T04 compressor wheel and modified compressor housing, it has a standard actuator so lower boost levels could be maintained..
Fats wrote:Alright, this is the problem i don't know the size with out stripping the housing off
MR2Mania wrote:rwilson_ie wrote:Basically, with an internally gated turbo, the entrance to the turbine housing has to flow both the"wastegated" gas and the gas that actually drives the turbine wheel.
There'll come a point when the turbine housing can't support enough flow for both of these together, and hence a restriction occurs, which causes back-pressure, and it's this back-pressure that stops the gases escape from the engine, meaning this has a knock on effect on intake temps, regardless of what the intercooling is doing.
Also, the back-pressure will be costing you power, hence why it's so difficult to get an internally gated turbo to flow well enough to support over 400fwhp.
With an external wastegate, the gases are released BEFORE they get to the turbine housing, and the inside of the housing only has to flow the gases that will be driving the turbine wheel.Hence, you can actually get a smaller housing
(which will give you better spool up) without affecting the flow at high RPM.
Also, a turbine housing that is designed to be NOT have an internal wastegate
(ie needs an external wastegate) has a much better flow path to the turbine wheel itself.
Thank you for all this info- I am getting a crash course in turbo education.
Some is still gone over my head and I'll have to read up a bit but I've learned a lot over the last two days.
And in hindsight, what you've told me nearly makes
"common sense"
Rob
