Markings/codes on pistons??
Paul R
Post by Paul R »
Hi,
While tinkering with my engine last night, I cleaned some carbon deposits off of the pistons and noticed that in the center of them, there is a marking.
The pistons in cylinder 1, 2 and 4 have the mark '2C', the piston in cylinder 3 has the mark '1C'.
Can someone tell me what these mean?
Cheers,
Paul.
JJ
Re: Markings/codes on pistons??
Post by JJ »
They're just original markings refering to the size of the pistons fitted to the bore. Toyota produce pistons to a very small tolerance to get the pistons as close to design specifications as engineeringly possible.
Paul R
Post by Paul R »
Hi,
OK, do I need to worry about these sizes when getting the cylinder over-bored for my new JE 86.5mm pistons?
Cheers,
Paul.
Renegade
Post by Renegade »
Nothing to worry about m8.
I did that job a couble of months ago
Je 86.5mm (9.0:1)
Eagle Rods
Cometic 1.5mm Gasket
Arp studs
Bearings Set
JJ
Post by JJ »
Not a problem - just make sure the machine shop are in the understanding that the clearances of the forged pistons need to be considered due to their higher expansion / contraction rates
Paul R
Post by Paul R »
JJ wrote:Not a problem - just make sure the machine shop are in the understanding that the clearances of the forged pistons need to be considered due to their higher expansion / contraction rates
Cool.
I'll take the instructions in that come with the pistons and point out the clearances :)
Paul.
Terry
Post by Terry »
Paul,
Just out of interest, what is the part number for the JE Rings you got in the kit?
The ones I've got dont match up with the part number that JE give on their Website? :?
Thanx Terry
Paul R
Post by Paul R »
Terry wrote:Paul,
Thanx Terry
Hi,
I'm not sure yet mate, I'm waiting for GTChris to get some more in stock......
Cheers,
Paul.
