Dave.
Did you replace the ones in the heater controls and key surround? How many do you recon you need in total?
mrrwaction1 wrote:Changing the lights in the heater control andwindow switch is not an easy job and thats even if you are good at soldering taking the electric window switch apart is quiet tricky if you decide to venture this far take care as there are lots of loose bits inside.To change the led's in the heater control to blue from green you require 3mm leds to replace the existing ones you will require a soldering iron and a desoldering tool and about three hours spare.
Davidbeaven wrote:Got some red Wide angle LED's the other day, planning on fitting them at the week end.then progressing onto the heater etc untill every thing matches nicely.
i'll post how i get on.
Dave.
Davidbeaven wrote:Kevin,
They look amazing! good even light spread.Infact better that the normal bulbs id say.
Now on top the centre consol, doors and roof.
I'll see if i can get a pic for u.
Ps as they are LED's they only work one way round so test before re-assembling the dashboard!
Dave
Does the needle have it's own bulb as i'd like green backlights with a brighter red needle?
