SonicSW20 wrote:Did you calibrate it when you reinstalled it? TPS is a very simple device, if it calibrates correctly then its fine.
I didn't remove it yesterday.
SonicSW20 wrote:Ah, I got you.![]()
I've only had Gen3's, but if you disconnect the TPS on those it'll hunt on idle, I don't know if Gen2 would behave the same.so perhaps if disconnecting it made no difference to the vehicles behaviour there is something wrong with it?
SonicSW20 wrote:Have you replaced/ tested the AFM? Searching on the US MR2 forums for heistation at 3000rpm
/ wont rev past 3000RPM brings up the AFM being an issue quite often.
SonicSW20 wrote:Has it run right since then? I've heard before that the AFM is pretty sensitive and opening them up isn't advisable as it's easy to break them.
SonicSW20 wrote:Sounds like a right nightmare![]()
Have you used Mr.Two's in Willenhall, assuming you're still in the West Mids? He did some work on my old NA when I was in Stafford, seemed decent and knowledgeable.
hojoos wrote:any kind of aftermarket boost controller on the car?
