pbmr2 wrote:my mate has a quaife diff and he loves it..
BUT!
it does add a lot of understeer, which isn't always ideal.
pbmr2 wrote:it's not my diff, on someone else's car.![]()
proper staggered setup, stepped up the same amount front and rear, with matching tyres.![]()
the diff adds understeer compared to the stock lsd.compared to my daily mk2 it's noticeable.
it grips really well and puts the power down very well.
using ohlins adjustable shocks all round.![]()
it really put me off wanting to upgrade my tubby diff from viscous.was quite interested in the quaife before having a go.
seemed on paper to be the best of both worlds.
off power it's fine but turning in under load you notice the front isn't as direct as it was.in the dry it's no where near as noticeable but in the wet it shows it's hand more.
use a bit of lift-off to compensate.
at parking speeds it's ok until using max or near max lock, liking coming out of jucntions slowly the inside wheel skips a bit.![]()
The thing I love the most about the MR2 is the front end.My daily NEVER gets understeer even when pressing on hard.
chuck it into a tight roundabout and take the micky with the entry speeds, get on the power early and leave the traffic for dead.
normal cars can't compete.
the quaife seemed to take some of that away from the car.at high speed on hard power it was good but lower speeds or tighter bends it definitely added some understeer.
do you run a quaife?
